69 dart k frame
I think the difference is a big washer was welded on the front of the k member on the 318's...........or was it the 340's? Maybe someone else here might confirm this?
no biggie for fitment then if thats the only difference ive had a couple of real 340 cars with no washer for what its worth:toothy10:
there is a horshoe looking gusset around the lower control arm mounting point and that washer welded to the front I guess to indicate a 340 K frame
the horshoe looking gussets around the lower control arm hole are reinforcements only found on the 340 K frames. Yes the washer in the front signifies 340 engine..
