69 Dart KH sbp front disc bearings and seals
Dartvader440gt
Tiverton
I've been searching and all I want is the front inner rotor bearings and seals for sbp KH discs for my 69 Dart resto. (Yup we're still at it almost 4 years later). Outers are fine. The inners and seals got a little damaged when I used a puller to get them off. Thanks for any help.
They are the same thing as for the 10 inch drum brakes.
Just order, buy, from anyone of your choosing,
Nothing special about them.
Common numbers for the bearings are A2 for the outers, and A6 for the inners. Seals are National # 6840S .
Which bearing is better? Timken or National?
National makes seals only AFAIK. Made in USA Timken, or Bower/BCA bearings are what I like. Older SKF and Toyo bearings are ok too. I was never an L&S fan, but, they've still probably better than some of the Chinesium stuff I've seen.
