69 DART SWINGER wing windows
sleepyhead416
Mcdonald pa
What years are the same ??? I bought a used one it dont fit. The leg were adjuster is is a little different.
Some have altered the part inside a 67 model door to work with a 68 up window assembly. I dont recall reading the opposite has been done.
As far as I know 68 and later for 2 door models are all the same.
The vent glass itself all interchanges from '67-76. The frames are different between body styles and some years. Some have a different curve to the handle but those can be swapped.
