69 dart
rm69dart
Costa Mesa, Calif.
hi
I need some advice, just got the car and iam going to paint it, but it came with a v- top i striped it out and found lots of rust,pits,holes. help8)
the roof of my car was terrible, first thing i did was use a chisel to get rid of all the bumps of loose rust/metal, then i sanded it all down, then i used naval jelly, then fixed holes with metal and jb weld, then body filler for the rest.
You need to remove ALL of the rust, then fill the holes with weld or new metal, depending on size. Once your bodywork is all finished, spray on a couple of good wet coats of epoxy primer, then some high build primer. If you're going to replace the vinyl top, then sand everything straight and smooth, and give it a least a couple of good coats of paint for future protection. If you aren't going to replace the vinyl, you may have to modify your chrome/stainless trim because you won't have the thickness of the vinyl when you go to re-install the trim, so it will fit kind of loose. Good luck.
