His Buddy may have ordered a rear Panel from them, but I'll bet he hasn't received it.
If he has, he's one of the few.
OER is the parent company (aka Chinese reproducer) for Classic Industries.
They advertise these pieces via Classic, but you just get put on BACK ORDER until a given number of people have ordered, then they produce them. If that given number is not reached, well, you're left waiting for quite awhile, if ever.
Lotsa Mopar Guys have ordered 68, 69 GTX GRILLES, 68 RR HEADLIGHT BEZELS and other parts and not received them in over 2 years. And, you guessed it, you receive Credit, not a refund.
WELCOME TO REALITY.
You can almost always recognize a Chinese repro part by the paint. It is way off OEM, because it is usually the cheapest paint/method they can use for a mass produced part. For instance, on this panel, you see the GTS badge area had been painted over. To mask it off would cut down on production run time.
So once you receive this part (assuming you do actually ONE DAY receive it), you have to remove the badge area paint, which is tough to do because you must strategically place paint remover into this badge area. Mess it up, you mess up your Panel.
