340plot
the bushy bush
i have a bone stock 340 that still has the 6/69 bearings in it. i had the crank checked. all it needs is to be polished. pistons are standard bore.
i have everything for the engine, minus valves for the heads. they are not x or j-heads.
this engine just needs a gasket and bearing kit, to be cleaned and reinstall.
i have a weiand intake for it, but no carb.
also have a 70 4 speed setup. with all linkages, hump, shifeter, pedals. flywheel, z-bar, and all the other goodies, minus a clutch-pressure plate. the trans is at a shop to be checked out, and it is good to go. i just need to pick it up.
this is everything to install this into a a-body.
1,800.00
1,800.00
