Welcome to this great site if I missed you in the welcome forum td96ram :cheers:
Look's like a great start and I bet you are glad to get the dash out :happy10:
That's a hand full to get dun :happy10:
I'm finally going to move forward with the Valiant,the thought of going with the 440 has now changed after i realized the cost wasn't going to work for me.So i traded the big block for a 360/904 combo and cash and will have the car at least running by fall.I will keep posting pics as i move along.
Tim
Here are some more pics of the engine compartment getting ready for paint.I'm going with something close to a 69 white color my question is what color do you paint the front frame rails? are they white or do you mask them off and go with black?I will black out the front of the core support and the k member will be black.
Tim
Factory the rails are body color- but remember that guys sprayed the undercoating and the black out by hand-held sprayer (in a pit below the car). Depending on what day it was, if the supply tank was a little low, how 'artistic' the line worker was feeling, et cetera- you could have very like to a ton of goo down there. Me? Do what you think looks good and makes you happy
Had some warm weather this week so it was time to paint, ended up going with a 69 color Alpine white. I will leave the frame rails white in the engine compartment and will black out the front of the core support.
I should make more progress this weekend an will post as i go along.
Tim
Thanks for following the build guy's and i will get some updated pics up soon. I just degreased the engine compartment really good and used a combination of surface conditioning discs on a little die grinder and scotch bright pads all from Harbor Freight.Yes Sedanman that is the front suspention i got from you, i'm going to go with the Scarebird front disc setup so i can still run the front 14" wheels with poverty caps.
Tim
