boosted
Life Needs Air
1969 Plymouth Valiant race car/pro street project.
Car has been mini tubbed with the springs moved inboard, sub frame connectors, 4 point roll bar is already welded in. Passenger side front floor pan half has been cut out for replacement and have the replacement pan half for it that comes with the car. The car has a 7 /14 rearend under it to just roll it around but do have a narrowed 8 3/4 BBP with long studs ready to go in it.. Just needs brake setup for it.. was thinking of a disk brake setup so that is why it has no brakes. Spring perch's are already welded on for the inboard springs. Over all body on the car is pretty good, has a fiberglass 6 pack hood, and the grill, factory steering column. It will need a dash or you will have to fab one out of sheet metal.
Allot of the hard work is done and this would make a nice race car. I measured the wheel house and there is 14" of room from inside to the factory lip...
First $1500 gets it all
... car is located in midland GA... It does not come with the two Rally wheels but I will put some stock Steele wheels on it.. They are small bolt pattern and would not work on the narrowed rear anyways.
Also comes with a complete 318 2v motor, 904 trans and a v8 k frame...
Pictures to come..
Pictures to come..
