69 valiant / to 340 shift linkage
Column, floor shift or trans throttle pressure linkage ?
The actual shift linkage should be the same, Possible a different rod from the bell crank to the trans. The throttle pressure linkage is available new, but its not cheap.
sorry, column shift. i bought the new kickdown cable. so you think everything should swap back over? also, if any body has the inspection plate cover for the trans. id be interested as well
The linkage from the Column to the bell crank, and the bell crank are the same. I believe the rod from the bell crank to the tranny is also the same So yes you should be in good shape.
I have heard good things about the kick down cable but havent used one yet.
The inspection cover of the trans will be different then your 904 cover. I believe big block 727 is also different.
