6pakattack Time
Slant 6 Engines
  1. Bill Dedman
    Bill Dedman bill dedman Legendary Member
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Well, I bought a Chevy once... in 1966... :eek:ops:
  2. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Sounds like a good idea, Charrlie!
  3. 6pakattack
    6pakattack Well-Known Member
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    Woo Hoo, ALMOST !!!!Stopped by to check on the Buzzin Half Dozen TODAY !RMD and 2 other Dash pieces are in and functional,2 fender mounted turn signal from Dave (340 Mouse)installed and functional, and the Gear Venders shaft finally came in. So that should go in today or tomorrow. All I need then is Exhaust. I've got the mufflers (Dyno Max Race Bullets), X pipe, and dual '71 Charger slotted tips !!! It's coming
    :blob::blob::blob::blob::blob:
  4. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    2 steps back again !!!Driveshaft (major PIMA)too short,need to get measurement again and see if they can get it right THIS time (5)!!! And time to try a smaller Carb !!! "Maybe" these are the "LAST" 2 obstacles, besides the exhaust ? Man I hope !!!!!!!!!
  5. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Dennis, just be glad you aren't removing the cylinder head to install O-rings... (I spent the day doing that...)
    That, due to a blown head gasket...
    Don't ever think you'd trade YOUR troubles for somebody else's....:violent1:
  6. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    If it got to that point Bill,I think I'd just sell the beast !!!
  7. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Cars like this aren't worth anything....
    If I thought I could recoup fifty-cents on the dollar, I'd sell it in a New York minute, but no chance of that....
    So.... I live with it.:eek:ops:
  8. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    To top it off, I fell down and found out that my face isn't NEARLY as solid as the trunklid of Feddie's '74 Lincoln Continental... and I'll have a nice shiner to prove it... and I think I may have fractured a rib.... sore as hell...
    Gettin old ain't fer sissies... :sad5:
  9. 805moparkid
    805moparkid Slant and AFX Guy
    11,533
    85
    Oct 29, 2008
    Anthem AZ
    Local Time:
    3:38 AM
    he was a body builder! and no i didn't look it up!
  10. 805moparkid
    11,533
    85
    Oct 29, 2008
    Anthem AZ
    Local Time:
    3:38 AM
    turn that damn carb!
  11. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    If I turned it,1.it would look ridiculous because then I'd have to turn the air cleaner the same direction and that look like chitt with the style air cleaner I'm using,2.then I'd have to go back and redo my throttle linkage which would mean new throttle cable and linkage bracket fabrication,3.I'm tired, I just want to get it done and enjoy it !! My last 2 ran just fine, so I'll stick with what I know works and save myself more grief !!
  12. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    What are the advantages of turning the carb on what is essentially a single-plane manifold like the Aussie Hurricane, Ed?
  13. Rockerdude
    Rockerdude Rock n' Roll and A-bodies
    2,395
    104
    Aug 10, 2007
    Arizona
    Local Time:
    5:38 AM
    My carb isn't turned on my Offy manifold because the adapter plate was not drilled to be turned. Is it really an issue?
  14. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    That was the same thing I ran into !
  15. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    Fuel flow ! Instead of the fuel being drawn from 2 barrels sideways, it draws from both barrels at the front ! At least that's my simple explanation !! I know what he's talking about, it's just that the manifold wasn't drilled to allow that, so I left well enough alone !! My two other 6's ran fine with the carbs the same direction so I'm not going to sweat it .
  16. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Are you talking about fuel flow or air flow??? Or both?
    Also, since it's an open-plenum manifold, there is the same vacuum signal beneath the venturis no matter how it's turned, isn't there?
    If that's true, what would be the advantage of rotating it 90-degrees?
    There's obviously something I don't understand, here.
    Vacuum is vacuum. The amount of vacuum acting on the carburetor is not going to change with an open plenum manifold like this, no matter how the carb is oriented. Is it???
    I just can't see it... explain it to me. Please...:violent1:
  17. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    OMG, finally I have my driveshaft back !! Unfortunately, not early enough to get it installed to be able to check it out before we head to the muffler shop !! Oh well, what's another few days ? Yet one more step closer !!
    On a positive note, the 390 Holley is working fine now, and the 340 Dipstick and Tube have a happy new home on my / !! Just gonna have to wait till Monday and see how far I get !!! :burnout::burnout::burnout:
  18. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Still waiting for an answer to this...
  19. Charrlie_S
    Charrlie_S Well-Known Member
    2,976
    820
    Oct 17, 2005
    Silver Springs, FL
    Local Time:
    6:38 AM
    Bill, Vacuum has nothing to do with it. It is air flow and fuel flow. And to a lesser extent the fuel "sloosh" in the float bowls. As the air/fuel flow leaves the bottom of the carb, it has to turn, several times to get to the cylinders. Fuel can drop out of suspension. You want the oriention of the carb to give the most equal air/fuel distribution. Even the amount the throttle blades are open effects how the air/fuel flows. Look at the old Direct Connection books, where they talk about "Dams" in the manifold runners, and different radius on the entrance to the runners. With a slant six I don't Know which way is better, as I have never tried back to back tests. On my 170 I run a 500 2bbl mounted side ways. On my 225, I have a 465 4 bbl mounted "normally" like a V-8.
  20. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Charrlie,
    Thanks for the explanation.
    Do you think there's any advantage, one way or another, in an engine running say, fifteen pounds of boost in a blow-thru?
  21. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    Woo Hoo, finally going to pick up tomorrow afternoon and take it to get the exhaust made up !!! What a helluva Birthday Present !!! :blob::blob::blob::blob::blob:
    :burnout::burnout::burnout::burnout::burnout:
  22. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Well, happy birthday, whenever it is!!! :cheers:
  23. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    The BUZZIN HALF DOZEN is home and ready to cruise ! One more prob I found though, a bent axle shaft !! No prob,my mechanic has one in his shop and should be able to take care of it next week !!! Now if these friggin rains would go away !!!!
  24. Bill Dedman
    4,006
    59
    Oct 16, 2007
    Conway, Arkansas
    Local Time:
    4:38 AM
    Congratulations!!! Now, go have some FUN!!!! You've waited a long time for this!!!!:blob::blob::blob:
  25. 6pakattack
    2,450
    33
    Sep 1, 2005
    Sebastian, Fl.
    Local Time:
    5:38 AM
    Yes I have Bill !!! Going to have to check into some type of Racing fuel to add to mine to eliminate knock !! Successfully made its maiden voyage to our local cruise-in,so that was a good thing !!
