Google "Ring and pinion" and you will get about 500 hits.
Many will say Randy's ring and pinion,but I found them much higher in price
Yukon,Richmond,and Motive are three common gear sets.
Motive is a very good gear set,and usually around $100.00 less than the others.
I have a 3.55 Motive ringe & pinion in my 65 7.25" rear with no problems.
You can get a motive set for about $150.00
2 notes:
1.Make sure it is for a early Chrysler and not a Dakota.A Dakote 7.25" gear WILL NOT WORK.
2.The spider gears for some reason were tough to find,so make sure they are for the early Chrysler 7.25" rear,and then make sure again.
They love to send you Dakota stuff,ask me how I know.
Good luck!!!!!!
