7 1/4 U Bolts
I would get the right ones tho that have a flat to it, local store would be round those don't grab that well.
me!!! i have a set with plates for 40.00 shipped. i have all 4 u bolts and shock plates for a 7 1/4.thanks,mike.
Your local leaf spring company should have them new. Good used ones should be good enough....If you're putting enough power to twist the axle housing in the u-bolt, you're going to break the rear end anyway.
It's funny you say that cause I don't remember ever seein u bolts with flats on a 8.750. In fact, I just put the 8.750 under my 63 from my Scamp and those u bolts had no flats.
