[WANTED] 7/16 Left Hand (LH) Thread wheel lug studs, '64 Barracuda
pete peterson
Active Member
swisher, ia
Rating - 0%
0   0   0
I need a LH 7/16 x 20 wheel lug stud for my 1964 Plymouth\Barracuda. Or if used, individual studs are not available, I could use a driver's side,
front brake drum complete with LH 7/16 x 20 wheel lug studs inserted. I do not want to replace all 10 driver's side LH studs with RH studs.
If I can buy a drum with studs, I will press out one of them to replace the one I twisted off or use the drum if it's still good.
I broke it off because the lugs had been on for > 20 years & were rusted on! New LH studs are no longer manufactured.
Blessings for a good holiday season.
pete
Check with "mobile parts" I believe is his handle . Got all sorts of nos parts. I think his name is Craig Stanley.
pete
This is tim in Ottumwa area
I had them $10 each
