pete peterson
Active Member
I need a LH 7/16 x 20 wheel lug stud for my 1964 Plymouth\Barracuda. Or if used, individual studs are not available, I could use a driver's side,
front brake drum complete with LH 7/16 x 20 wheel lug studs inserted. I do not want to replace all 10 driver's side LH studs with RH studs.
If I can buy a drum with studs, I will press out one of them to replace the one I twisted off or use the drum if it's still good.
I broke it off because the lugs had been on for > 20 years & were rusted on! New LH studs are no longer manufactured.
Blessings for a good holiday season.
pete
pete
