roy villarreal
Ol 71
will the shafts from a large bolt pattern 7.75 diff fit in a 7.75 diff with smaLL BOLT PATTERN? CAN THEY BE SWAPPED OUT WITH OUT ANT PROBLEM?
The 7 1/4 is not a removable pig.i think he means a 7 1/4 with a center drop out pig
that was a joke....i know it was in bad taste my badThe 7 1/4 is not a removable pig.
oops i did mean 7.25 my type o.Does anyone know if the two bolt patterns are interchangeable or is there a difference in the shafts splines and diameter or length ?are they identical?
