69Chrgr
Charger/Cuda
Well, I spanked the Bird, but still disappointed in my time. It doesn't launch out of the hole like it should, so where do I start? Here is my combination:
360 Magnum block bores .030
Eagle 4.00 crank
Eagle I-beam rods
Protru forged pistons
chrome moly rings
block zero decked
Windage tray
Milodon 8 quart pan
ATI Balancer
ARP main and head bolts
Eddy heads out of box, no porting
Hughes custom hyd. roller cam .565 exh., .555 int., 305 duration?
Hughes matched valve springs
crane 1.6 roller rockers
M1 single plane intake
750 Quick Fuel D.P. Q series
March Underdrive Pulleys
Electric Fan
MSD Ignition
Compression 11:1?
4.11 w/Powertraxx
M/T ET Streets 275/60
SuperStock Springs
Pinion Snubber
My plugs seem to be fouling, turning black, so I know it is a rich condition, however I think it is only at idle. However I have to let it warm up to 180 degrees, so maybe my idle circuit is rich? My time wasn't awful, however you can tell it has so much more in it. Oh, yeah, it's in a 68 Cuda notch. Any ideas?
Eagle 4.00 crank
Eagle I-beam rods
chrome moly rings
block zero decked
Windage tray
Milodon 8 quart pan
ATI Balancer
Electric Fan
MSD Ignition
Compression 11:1?
4.11 w/Powertraxx
SuperStock Springs
Pinion Snubber
