7 Bladed steel fan or flex fan,which do you prefer ?
MR.7DUSTER3
His money, My time
Anaheim, Ca.
Which do you guys prefer the stock 7 blade or an after market flex fan.We have the 7 blade steel fan that came off the /225 but were thinking about getting one of the flex fans from Summit just for looks basically.Which will work better at keeping the 360 cool ?
How about a 5 blade mopar performance with a viscous clutch...efficient cooling with low drag at speed. That is what I'm shifting to shortly.
What does the rest of your engine compartment detailing look like? Stock type fan shroud? Other goodies custom detailing? Either of your choices would look good...depending on the rest of the details.
Good luck. I always seem to think too much on my project with questions like yours.
I haved used all three on my 67 cuda when it was 340 powered. I found the vicious fan setup to be the best, but make sure you run a fan shroud.
Basically any of three setup will work fine with a shroud, but will have issues if you run without a shroud.
Bob
