clhyer
- Joined
- Feb 24, 2007
- Messages
- 3,734
- Reaction score
- 320
I just done some repairs to my grill and thought that I would share. It was fairly easy, and relatively inexpensive. I did three separate "repairs" that I think are common to our grills.
The first repair is the upper mounting tabs that broke off. You can see that it was repaired before, and that was fine until I needed to remove the grill for a/c install. The mounting tabs broke off again.View attachment DSC01431.jpg
For this repair I went to Lowes and picked up a piece of .093 Lexan plexiglass. I choose this as it seemed to be more flexible than the standard plexi. I think the 8X10 piece was around $4 or $5.View attachment DSC01432.jpg
I wanted to fit this plexi into the groove on the top of the grill, it required a couple minutes of sanding with 80 grit to get a nice snug fit.View attachment DSC01433.jpg
The mounting tab that is broken off only has a partial groove. I notched the plexi so that the tab fit snuggly on the end. When cutting plexiglass, I use my scroll saw on a very slow speed. If you cut too fast the plexi heats up and melts back together right behind the blade. By using a very slow blade speed and feed as fast as possible I get a good clean cut that cleans up with just a couple swipes of the sanding block.
After notching the plexi for the tab, mock up the fit and trace the outline of the pattern. Drill the holes first while you have a large piece of plexi and use a round file to do clean up. I clamped the plexi in a vice close to the holes. Then it was back to the scroll saw to cut it out.
Hit the edges with the sanding block, mount the U nut and check the fit:
TO BE CONTINUED...
TO BE CONTINUED...
