[Found!] 70-76 A-body instrument cluster pigtail
j_anderson
Fort Wayne, Indiana
If anyone has a dash harness they are cutting up, I am in need of the main instrument cluster connector and 6-8" of the the wiring. This is the round connector that plugs into the PCB on the back side of the cluster. I see a couple on eBay from 70's/80's trucks for 10ish dollars but the wiring isn't long enough for what I want to do.
I am putting aftermarket gauges in my car and I would like to make an adapter harness for easy change back to factory gauges in the future.
These are two I found on eBay. Either of these styles would work. I just need more wire length. Let me know what you've got!
lol you can add due what’s missing easy. They are adaptable the slide right out? Good luck
I don’t have the terminals to add more and unfortunately I don’t know where to get them. That’s why I need the amount already in the connector. Or more than one and combine to get what I need
