70-76 Instrument cluster.
cascius
Overbrook, KS
I've got an instrument cluster removed from a '76 Scamp. Bezel is in relatively decent shape. It has one broken piece above the column and a couple cracks on the lower edge. I don't know if it worked or not as I never had the car running or hooked to power to check it out. I didn't even think about looking at the plug in on the back when I took the picture tonight. I don't know if I'll be out to my parents again any time soon to double check and make sure the connector pins are all intact. $75 shipped to your door. Paypal or money order are acceptable forms of payment.
Had a chance to look at this again tonight. Pins on the back are all in good, solid condition. All the light bulb plugs are there, speedo housing appears to be in good visual shape, still has the silver box (resistor?) plugged in the back. Has a little bit of corrosion starting on the back of the contact board, but nothing major.
