wafastr
Active Member
I will need the column shift linkage for my 70 Dart project as follows: column linkage to the cross bar, the cross bar, and linkage to the trans. I have the cross bar and linkage from the s6/904, but don't know if it will fit the 727. Will sb/904 linkage work?
I will also need the kickdown linkage as follows: linkage from the snap on pivot on the throttle cable bracket, the bell crank mounted on the trans, the threaded pivot pin for the bell crank, and the linkage to the trans.
I have the throttle cable bracket and linkage to the carb. Thanks for the help FABO members.
I have Paypal. Shipping to Sagle ID, 83860.
