[WANTED] 70 Dart side molding clips
I'm looking for some side body molding clips for the 70 dart. The plastic type.
Thanks !
Try RT Specialties. These are for the plastic clips that are attached to the mushroom studs on the body, correct?
There are some Volkswagen trim molding clips, maybe 90's Jetta's, that are very similar to those clips.
I have nos plastic clips that come with the screws for installing new panels back in the day. I will post a pic of them next to a ruler so you can see them later this evening.
Any luck on the pictures? I'd be interested in these, if you are willing to part.
Sure here they are these are clips packages for the old mopars that ended up with new panels.... I have a bunch of them. Let me know then.
I understand that those plastic pieces probably fit into the trim, but how do those then attach to the body? Those screws look to small compared to the hole in the body, unless these were designed to screw into a panel with no holes...
Do you have a part no on those kits? Just wanna be sure the plastic will for sure fit the 70 Dart side trim. Also how many clips in a kit?
That is one kit. They are made to use the Philips screw to fasten the clip for when replacement panels were installed. No part numbers on them as far as I remember.
