[SOLD] 70 Dart Swinger
dshaw49
Member
Middleburg, Fl
Rating - 0%
0   0   0
Hate to part with the Dart but starting a new project. This car is built right and runs as good as it looks.
$25k OBO
Engine: 360 Block (Machine Work - Indy Cyl. Heads)
Comp Cam - 20-601-9, Roller Cam & Lifters
Diamond Pistons - 51405 9.5 Comp.
Bore 4.030 Total Seal Rings
Eagle I-beam Rods and Eagle Cast Crank
4.00 Stroke, M77 Rod and Main Bearings
Edelbrock Air Gap Intake
Holley 780 Double Pumper Blue Printed for Engine
Mopar Performance Valve Covers
Edelbrock Heads-035060779
Milodon RoadRace Pan-31595
M.P. Oil Filter Angle Adapter
TTI Headers-
Fluid Dampner-Balancer
MSD Ignition, Distributor, Coil, Control Box and Wires
Schumacher Motor and Transmission Mounts
Wizard Aluminum Radiator and Custom Shroud
Transmission: 904
5.0 Kickdown
Kevlar Bands
Blue Clutches and Kolene Steels
Multi-Spring Clutch
Turbo Action 19801 Converter
Turbo Action Cheetah Valve Body
Rear End:
8 3/4 Rear End - #9 Chunk Posi Unit
Narrowed Spring Perches, with Springs Moved Inward
Moser 30 Spline Axels
Cal-Trac Traction Bars
Suspension:
Hotchkis Sway Bars Front and Rear
QAI - Upper Control Arms
SSBC Disc Brake Conversion W153-6
3" Stainless Exhaust
Mancini Racing Frame Connectors - Welded In
15 x 10 and 15 x 6 Weld Prostar Wheels
Mini-Tubs and Trunk Mounted Battery
Off topic what rear sway bar did you use with the leaf springs moved inboard? Beautiful car by the way.
I used Hotchkis on both front and rear. The 1" just fit perfectly on the rear, big sway bars really made the car a pleasure to drive now.
Yes it did. He just stopped by my house with it this morning. Very nice car, looks like a real solid build. What rear springs are on the car with the caltracs ?
What color is this car? My 70 dart was originally B7 blue with a white top and B7 interior. It seems like B5 is a MUCH more popular color.
