waggin
moving on ain't easy if you drive a Ford :p
8500 FIRM as is where is 73 340 freshened up with mild cam aluminum intake dc valve covers 727 trans with 3000 stall on the column. 8 3/4 w 2;76 comes with the car, custom rally's,340 k frame with sway bars, 10" drums all around from factory, air conditioning (missing a couple parts 1 brace and one hose then service it) and power steering from factory
new amd full floor pan , new lower 1/4's fronts and rears, new carpet, new headliner all lights work, new sill plates and many new parts installed just needs finishing, everything is cut in except trunk and car deserves a new trunk pan to go with the other work I have done to the car(the underside looks as clean as the topside) new dual scoops from partsmix installed
