gregpurcell
Greg Purcell
I have a 71 340 .30 over block date code 6/17/71. The block vin is 2G11508. The top deck number is M340RJ0000225. (all pictured below). I have 3 J heads with 188 intake valves. I have the forged crank cut .20 on the mains .10 on the rods . I have a set of stock rods but no pistons.
I am told the motor was together and running but it was losing compression on the number 8 cylinder so it will probably have to go .40 (or you could sleeve #8). Someone broke an extractor in the exhaust port of one of the heads. You could probably run manifolds without that bolt but that's why there's a spare head. The crank is rusty from sitting so it will need turned more.
Located in Savannah, GA I CANNOT ship but I can deliver to Carlisle if I get a non refundable deposit. Asking $1050
Thanks for looking!
Thanks for looking!
