71/4 axle removal
speedyb-cc
speedyb
San Marcos, TX
How do the axles come out of the 71/4? I have the cover off, not seeing any c-rings. It has the 10" drums, 4" bolt pattern.
Thanks and God Bless
Bruce
First pull the drums off, then there is a hole in the axle flange, going through that hole with a socket, remove nuts (4) 9/16 holding backing plate and bearing cover. Take a slide hammer and it should come right out.
