71 Dart get 408/ Trick Flow Heads....
Mopar Racers Forum
  1. 19DUSTER73
    19DUSTER73 Well-Known Member
    238
    184
    May 29, 2010
    Chehalis, WA
    Local Time:
    11:53 PM
    I have wondered about this also. The supply is much smaller than factory also. Which may be a needed improvement as some guys will restrict oil up top anyhow.
  2. flyfish
    flyfish C8H18+N2O = :-D
    2,284
    868
    Apr 16, 2007
    Indy
    Local Time:
    2:53 AM
    So sorry to hear about this Tony. I hope everything else survived. I have the same cam in my 408, but so far so good.
    • Agree Agree x 2
    • 70aarcuda
      70aarcuda Master Hoader of SBM FABO Gold Member
      16,304
      4956
      Jan 16, 2005
      las vegas
      Local Time:
      11:53 PM
      Wow...it was not as bad as I thought it was...I still got 4 lobes that are not flatten...LOL.....the other 12 lifter had to be removed out of the bottom of the cam tunnel...
      Damage report.....cam ...and lifters....HV oil pump.....check a couple main bearing....those are being replaced...and the rod bearing too...plus gaskets....
      the oil pump was very hard to turn .........alot of metal shaving and pitting...
      cylinder walls all look good....no problems with cam bearing....that amazing....
      probably strip the block and hit it will high pressure washer.......
