[FOR SALE] 71 Dart Part OUT
RAT ROD AL
MOPAR ARCHAEOLOGIST - one parts hoard at a time!
Robbinsville, North Carolina
I picked up this car last week also. It actually has a North Carolina Title but is to far gone in my opinion to save. Floors are rotted out, Rt side 1/4 is gone, no trunk floor . Frame rails have been fabricated and moved inboard . It came with extra doors and fenders, grills and bumpers. Most this stuff is to big or expensive to ship, keeping that in mind I will gladly have local pick up and or delivery. I also have a S/W road trip planned (sorta ) early August to College Station Texas and other points unknown ! So if you want something I may be able to deliver it to you !
Here's a brief description of what it has left .
Make offer on anything you like !
8 1/4" , 3.21 sure grip rearend. Big bolt pattern
9" drums on front, no swaybar.
Front Frame Rails look good.
Pair of Cragar ss on front small bolt.
Doors are in good shape , but mostly just a shell. No glass or regulators.
Roof looks to be in nice shape !
Left 1/4 has some good metal in it. Rotted at the bottom rear and cut at the wheel opening.
Front fender splash shields are decent.
I can post up any pics you need of something in Question.
Here are pics of the loose parts I have with it.
All prices + shipping from FL. 33956
Taillights $65. Pig tales have been clipped.
$50 for this pair of 1/4 caps. each one has 1 stud missing, other than that in good shape.
71 I believe
Someone sprayed it Good shape , but has a couple mounting tabs missing. Nice driver.
$125
73 grill. In nice shape. No broken fins in grill couple small dings in light bezel. The top right speed nut hole is messed up. $150
Bumpers are nice and straight. Need polished up , or painted, good to go for a driver.
$75 each
beaker nose $60
rear valances gray one $75
black one $60
Both need some work , no rust.
Rear with lights and brackets. $150
Scroll down for more parts. AS always, Thanks for looking.
73 top of door trim . Not perfect bot pretty nice. One of them has a small chip out of it.
$30 for the pair.
73 door cards. Nice and clean and flat. one has a very small nick in the bottom edge. $200
Duster fender, nice and straight, has had a couple repairs made on it. Wouldn't take much to make it nice. ( is this maybe a demon fender ?)
$150
71 Dart fenders $150 each.
This left one has a small rust hole in the lower rear skin, bracing is ok. Not beat up or dented
This is all good.
Car has a nice pair of 71 doors , as stated above , no glass or regulators.
Also have pair of 73 doors in decent shape. With all the glass in them. Will post some pics asap of them. Check back as I may find more parts ! Thanks for looking !
I also have a pair of 73 up dart fenders. Good for patch panels or repair.
Also a front bumper and brackets. Looks straight but has been painted.
More parts pulled today from the dart
Frame rails look decent, crossmember is cut short on the right side.
The roof is in decent shape also. The center roof support had been removed .
Small parts,
$40 for the pair.
14" x 6" with 3 1/2" Back spacing. Some rust that may clean up ,
caps are nice !
LCAs need new bushings. Good condition. $40
Center Link $20
Tie Rod Links $10 for the pair.
Bracket $10
Strut Rods , missing all nuts. $20
Torsion Bars
# 888 R
889 L
$10 pair
Splash shields , decent shape not rotted out. $40
Shock Mounts/spring clamps . Were on an 8 1/4 , but look like they fit 8 3/4s also. $30.....SOLD.....JD
3" U bolts $10 ....SOLD...... JD
Front spring hangers $30
Rear Hangers $20
Long shackles $10
8 1/4 snubber $15
Bundle and save on shipping .
More parts coming.
Steering column $40
I don't know if it's P/S or Manual
9" drums with small ball joint UCAs & small bolt pattern lugs
Will split up if you want pieces.
Hood latch & support. $40
Roof rail SS trim for window seals . Nice and clean . With screws $50
Rear quarter light holes. $15 for the pair. ( someone was just looking for some )....SOLD...
V8 K frame. ....SOLD....
Good condition.
Looks a little bent in the center from jacking , not bad. $100
Would you happen to have the complete radio antenna mast and cable that went from mast to radio?
I have another road trip this weekend up to the DC / Virginia area. I can possibly deliver some of this stuff if on route . S/W Florida to Jacksonville Fl, then up 95 to the DC area. Leaving here this coming Fri.
Sorry just saw the part in one of the photos and was hoping that you still had it
