mrcrrc
Member
Converting from drum/drum manual brakes to KH 4 piston/drum power brakes. I bought new lines and found out that the original proportioning valve has different size fittings than the lines. I tried a B Body valve with no luck either. I am looking to stay as correct as possible so no aftermarket adjustable.
Thanks, Mark
Thanks, Mark
