71 Demon 340 Help
KilllWill
Member
I was wondering whats the biggest wheel/tire combo I could go with on my 71 Demon without making any serious modifications. I've also had issues figuring out which bolt pattern I should be looking at. Is it 5x4.5, or 5x4? Your help is much appreciated.
-Will
If it has stock axles in it, it's 5x4"
Largest tire without cutting/moving stuff is likely a 255/60/15. I know guys that have 275's under them but it's tight.
this will help with bolt pattern.
http://www.tirerack.com/wheels/tech/techpage.jsp?techid=92&
265 50 on the demon.
:cheers:Thank you both! The info you gave me was just what I was looking for. Much appreciated.:cheers:
