1. Who makes the better engine mount swap kit from 6cyl. to V8?
2. the AVS carb for the 340 is a #4401 for a auto trans. is there any difference between the carb for the auto trans and the carb for the manual trans?
3. And also any suggestions on cam?
Thanks for the input and advice.
I have personally used this kit and it works just fine for '67-'72 k frames!
The best deal money wise on a motor mount kit is:
Trans-Dapt Performance Products 4695 - Trans-Dapt Performance Engine Swap Motor Mounts
Trans-Dapt Performance Products 4695 - Trans-Dapt Performance Engine Swap Motor Mounts large image
$59.95
+ Wish List
+ compare
Motor Mounts, Swap Mount, Steel/Rubber, Black/Black, Dodge, Plymouth, Barracuda/Dart/Scamp, V8 to Slant 6, Kit
Application Specific
Application Specific Part: Check Application
Estimated Ship Date: Tomorrow
Bookmark and Share
Email
Overview
Application
Repair Parts
Show All
Large Image
Brand Trans-Dapt Performance Products
Manufacturer's Part Number 4695
Part Type Motor Mounts and Inserts
Product Line Trans-Dapt Performance Engine Swap Motor Mounts
Summit Racing Part Number TRD-4695
UPC 086923046950
Motor Mount Style Complete mount
Bushing Material Rubber
Bushing Color Black
Bracket Included Yes
Bracket Finish Black
Transmission Mount Included No
Quantity Sold as a kit.
Notes Designed to put a V8 engine into cars originally equipped with a slant 6.
When swapping out the engine in your hot rod, you need motor mounts that you can count on. Trans-Dapt has done all of the work for you in making these engine swap motor mounts. They're specifically designed for your application, so you can be assured of a perfect fit and great performance.
Warranty[/QUOTE]
Good lead but why do they only list up to 1972 ????????
