71 Duster blew it up !!!!
WIKD71RICK
ST LOUIS MO
Had the car for a little over 2 years.Lots of sreet time,track about 5-6 times a year.Monstor Mopar St.Louis 3rd pass OUCH.Time to upgrade.Promax in Indy built me a 512 pump gas motor.Going to see the final tune and dyno pulls this Sunday.Looking for a liitle over 600 H.P.at the flywhheel.The cars wireing was a liitle jacked up so all new painless going in.PAINLESS?????? Also built new dash insert.I was very pleased with the way that turned out.The
old motor ran best of 10.97 on street slicks thru the mufflers.
That thing should be a beast. What let go in the old motor? Got pics? Thanks for sharing.
Good luck at the dyno. I've also got a 512 which has yet to be fired...
Painless wiring, wasn't for me... They miswired three connections in the fuseblock and switchbox!! I had to call and ask for a full schematic so I could figure out what their flunkies did wrong:rolleyes:
It swallowed a valve on the big end,hole in piston,cracked cylinder wall and stuck the valve in edelbrock RPM head.Got pictures but still having problems posting them.
Is that based on a 440 block? What are the heads? Give us some specs on that motor to drool over...
50 More hours,feel like a 5 year old kid waiting for the Mopar Santa Claus.Yes its a 440 block,Brodix BS heads ported,BRC crank,Charlies drag pan .620 solid roller cam.Will get full blueprint Sunday Sunday Sunday.And no more $9.00 a gallon fuel.Need to save that money to pay for all this.HA HA:-D
$9 a gallon for the street at anytime is to much.
Theres more than one way to skin a cat.
Check out these guys, for under 200 bucks to your door you can get one of these and they are big fat factory gauge wires, so no relays or extra wires needed. I mount them in the back of the glove box and they look great.
Ive installed several of them and HIGHLY RECOMMEND THEM..........pm me for any questions
check them out........About 6 of these of these have them 70 gtx clone , 67 cuda, 70 cuda, 69 runner, and a couple more.
http://s297.photobucket.com/home/fistymopar/allalbums
http://www.ezwiring.com/
I can get more pics of under the dash.... they are easily connectable to the factory dash, too. I specailize in wiring so if you need it done.......wiring questions....
Sorry for the double picture.Having trouble posting other pictures
<div style="width:480px;text-align:right;"><embed width="480" height="360" src="http://static.pbsrc.com/flash/rss_slideshow.swf" flashvars="rssFeed=http%3A%2F%2Ffeed887.photobucket.com%2Falbums%2Fac73%2Fwikd71rick%2Fblew%2520it%2520up%2520time%2520for%2520upgrade%2Ffeed.rss" type="application/x-shockwave-flash" wmode="transparent" /><a href="http://photobucket.com/redirect/album?showShareLB=1" target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_geturs.gif" style="border:none;" /></a><a href="http://s887.photobucket.com/albums/ac73/wikd71rick/blew it up time for upgrade/" target="_blank"><img src="http://pic.pbsrc.com/share/icons/embed/btn_viewall.gif" style="border:none;" /></a></div>
