71 hemi orange swinger rescue.
Members Restorations
  1. chryslerfat
    chryslerfat Well-Known Member
    13,430
    7501
    Aug 23, 2008
    Monroe,Michigan
    Local Time:
    4:35 AM
    • Like Like x 1
    • Jadaharabi
      Jadaharabi FABO Gold Member FABO Gold Member
      7,718
      8464
      Jan 8, 2016
      Peoria, Illinois
      Local Time:
      3:35 AM
      Lol, my arm gets tired using a manual fuel pump so I use a mechanical or electric one.
      • Like Like x 2
      • Thanks! Thanks! x 1
      • Stephen Hotz
        Stephen Hotz Well-Known Member
        2,867
        2795
        Dec 30, 2017
        New Braunfels, Tx
        Local Time:
        3:35 AM
        :rofl: fixed.
        • Like Like x 1
        • Stephen Hotz
          2,867
          2795
          Dec 30, 2017
          New Braunfels, Tx
          Local Time:
          3:35 AM
          Well hit a speed bump. Got another timing cover inbound. 20200929_202648.jpg 20200929_203832.jpg 20200929_203837.jpg
        • Jadaharabi
          7,718
          8464
          Jan 8, 2016
          Peoria, Illinois
          Local Time:
          3:35 AM
          • Agree Agree x 2
          • mygasser
            mygasser FABO Gold Member FABO Gold Member
            674
            376
            Aug 17, 2010
            faversham, kent. united kingdom
            Local Time:
            3:35 AM
            you've got no sense of adventure :rofl:
            • Like Like x 2
            • Stephen Hotz
              2,867
              2795
              Dec 30, 2017
              New Braunfels, Tx
              Local Time:
              3:35 AM
              Speed bump #2 was broken tap while drilling the heads for the LA bolt pattern. Got it out though so all good.
              • Like Like x 1
              • Stephen Hotz
                2,867
                2795
                Dec 30, 2017
                New Braunfels, Tx
                Local Time:
                3:35 AM
                20201002_180335.jpg So other projects getting in the way. But got the heads finished up and on the short block. Still need to pull the idler pully mount off the one head but it made putting the head on way easier.
                • Disagree Disagree x 1
                • Stephen Hotz
                  2,867
                  2795
                  Dec 30, 2017
                  New Braunfels, Tx
                  Local Time:
                  3:35 AM
                  Got the rocker arms in and torqued as well as cleaned up the underside and mateing surfaces on the first intake manifold set to grace this engine.
                  Intake 1 is the stock 2V intake with testing on the stock and holley 500cfm carbs
                  Intake 2 is a 340 cast iron 4V
                  Intake 3 is a keggar intake
                  Intake 4 (maybe) modified intake for boost, or the tunnel ram.
                • mygasser
                  674
                  376
                  Aug 17, 2010
                  Local Time:
                  3:35 AM
                  i'd be straight to intake option #4 :thumbsup:
                  neil.
                  • Like Like x 1
                  • dartfreak75
                    dartfreak75 Restore it, Dont part it! FABO Gold Member
                    8,503
                    5968
                    Aug 10, 2011
                    Virginia
                    Local Time:
                    4:35 AM
                    Following this one. I like what your doing!
                  • missing linc
                    missing linc Loose nut behind the wheel
                    1,983
                    2977
                    Feb 17, 2019
                    Southern Alberta Canada
                    Local Time:
                    2:35 AM
                    Making great progress, will be watching this one.
                  • Jadaharabi
                    7,718
                    8464
                    Jan 8, 2016
                    Peoria, Illinois
                    Local Time:
                    3:35 AM
                    #3 A kegger is a dry intake used with fuel injection. What's your plan?
                  • Stephen Hotz
                    2,867
                    2795
                    Dec 30, 2017
                    New Braunfels, Tx
                    Local Time:
                    3:35 AM
                    Megasquirt with the internal baffle and wedge mod.
                    Kegger VRP with one of his cams.
                    • Like Like x 1
                    • Stephen Hotz
                      2,867
                      2795
                      Dec 30, 2017
                      New Braunfels, Tx
                      Local Time:
                      3:35 AM
                      Doesnt make much more sense than I want to know.
