[SOLD] 72 340 block
Mopar44134
Ohio
2-9-72 340 block, pulled the motor to replace the thrust bearing. Never got around to it. I coated the cylinder walls will an oil and grease combo to prevent rust. Hoping to get $350 for it.
First pic, straight down from the clock and below the drain plug, hit that with a wire brush along the pan rail and get the vin off the block please.
Where are you located?
crank numbers 3462387. Rod numbers 3418645. pad number 3B187781 I'm located in Parma, 44134
