71scamp78
I have a 1972 340 block..build date is 2/9/72. I have a set of 915 j heads with j heads. I also have the rods and cast 340 crank. The oil pan, factory windage tray and timing cover will come with also. I will take 750 for all I may separate. The block is standard bore and cylinders look good. It barley has a lip at top of bore. It's been sitting in shop for 20 yrs so parts are real dirty looking. I'm located in Terre haute Indiana. The numbers by oil pan are 3b126406. 40168019 is the numbers below drivers side cylinder head
