If you have a build date of 1/72 then the casting date on your motor should be somewhere in the 4th quarter of 71......Keep it consistent with the factory logistics of supply line available to keep the production line running.
Thanks everyone for the info. I'm confused about the date thing, I get the original motor date should be late 71 but I assume that a warranted motor would be replaced some time after the car was sold and maybe blown up or whatever. ? So wouldn't the replacement motor(block) be dated after the car build date? Thanks
Oldmanmopar just a question.. wasn't the -1 and through the span of that -4 and -5 the core shift? A realignment of the core to get it back to acceptable tolerances? If that's the case wouldn't the first batch of -2 be tighter than the last ones of the 1? Just trying to not over hype the stamped numbers. I'm learning and there's a lot to learn!
Dale
