junior636
72 Dart - 440 big block - stock steel crank and rods - forged speed pro pistons - edelbrock rpm heads and intake - ARP main studs - head studs and rod bolts -fresh motor. Gerst rack and pinion front end - Gerst triangulated 4 link rear suspension with Dana 60 - Borg Warner s475-t6 1.32ar with custom built stainless headers and plumbing. Csu 750 blow through carb - Snow performance meth injection kit with boost gauge - a1000 fuel pump and aeromotive boost reference regulator. Car has been rewired from tail lights to head lights - Aem o2 sensor and wide band - hellcat brushless fans - Fiberglass fenders and hood - Has a built 727 that I'd like to keep but not a deal breaker. I'm sure I'm forgetting some things. Car needs plumbing for fuel system finished (I have all the -10 hose and fittings) and it needs the wiring for all the new turbo system stuff hooked up. Really close to finished but something has come up. $15k as it sits or $10k for the roller. Located in coopersville mi 49404.
