72' demon grill and headlight bezels
Stacked360
I tried to fit the bezels that came with the car, onto the car today and they fit, and look correct, but look like crap...anyone know if these are correct or what could be causing the gap at the top corner to be so large?
You need to mount the grille flange on top of the support. You currently have it under the flange.
Change that orientation and the bezels should be in a better position.
It got a little better but still has a decently large gap at the top, fenders are in the right spots...
The grille and the fender extensions were on the car before and looked right??
Some Dart's/Demons came with the chrome around the "eyelids" and there are two different fender extensions....at least as I understand.
You might have to reset the standoff the bezel screws are attaching in. They were way off in the first pic the way the bezel is sitting.
Extensions are all the same with and without chrome trim.
I have one that is tight, another that is very wide as far as gaps.
Ditto on mounting the grille on the flange rather than below it.
Check the location of the headlight "bucket brackets". These brackets are the ones that mount on the radiator support and the headlight assembly attaches to it. There's a little "wiggle room" that should allow you to raise the headlamp and allow the grille to sit a little higher.
Also check the hood latch support assembly and make sure the flange is not bent down. Hope this helps.
72 Demon is right. The grill mounts above the radiator support.
