[SOLD] 72 Demon
karlaj51
Member
canada
Rating - 0%
0   0   0
72 Demon original 340-4speed, non numbers matching engine. All body numbers match (dash fender tag rad support) Older restoration Excellent condition 8 3/4 sure trac 323 gears, manual steering, power brakes. Located in Vancouver, Canada $25,500.00 US
Is an original 340-4speed car Fenders And grille were replaced with 71 Everything else is 72 Engine is rebuilt 70 block with steel crank, aluminum heads etc
Let's drop to the very basic. What's on the title? Does it have a title?
Lots of people prefer 71 grille and fender side markers. Biggest problem is it does not match the rear.
Would it have the small pattern ( 5 on 4") wheels? How long ago was the paint and body done? Bills for engine work etc ? Do the stock gauges work or just the under dash ones?
It is the small pattern, the paint and body was done seven years ago, unfortunately I have no bills for the engine build and have described it from what I can see. Most gauges do work. Thanks
