joeolddart
New Member
It is a 72 swinger look like 70 dart h code. The car was done using CAR CRAFT ARTICLE ENGINE SWAP DECEMBER OF 2000 .This car was strip to bare then painted in and out dymat inside and under car was undercoated .We have a 69 hp 440 block rebuilt roller rockers purple cam Edelbrock heads and intake , engine dyno at 480 hp, 500 ft lbs torque, 727 trans tci 3400 stall convertor valve body kit deep aluminium pan. 8 3/4 rear end with 489 case randy ring and pinion, we used Yukon gears and axles and new possie gear ratio is 430 .Dash was rebuilt with new guages it is a h code dash all wiring has been done . Has floor console s&w guages 2010 challenger front seats. just to much to list . We have a book on the car and dyno sheet. Have lot's of pix of car
asking $29000. firm
asking $29000. firm
