71scamp78
I'm selling all my stuff including this Dart and it will come with a ton of extra parts. First this a 72 dart non 340 car will add Vin later. It's from California so very solid 99 percent rust free. This a roller was a running driving car last fall pulled to build stroker but I can't physically do this anymore. Here's the break down it had a 360 so it's ready for your small block. It's been mini tubbed and springs moved in. Has huge 325/50/15 on back but there toast. Has skinnies on front all.on Weld wheels. It has the big bolt pattern with disc brakes, tubular upper control arms and new master cylinder. It has manual brakes and manual steering. Comes with complete msd ignition, brand new Champion radiator with dual electric fans with relays to kick.on fans . Has brand new battery in trunk with new relocation kit. Has brand new 3/8 sending unit, new 3/8 fuel line to front of car. Has brand new just installed sure grip unit from Cass at Dr. Diff with crush sleeve eliminator. Also new big 1350 pinion yoke. Interior looks good all the lights worked has new heater core. Car has one rust spot in front of right rear tire on rocker area. Drop a engine in and slap on a better paint job and u got a sweet car. Comes with a set of Doug's ceramic headers only ran for 200 miles before engine was pulled. Will come with two 360 engines one is a long block 78 360 not torn apart standard bore other is a 96 magnum engine tore apart. Also will throw in a 727 small block trans a few good alternators, two good radiators, new starter and more stuff as well it all needs to. Located in Terre Haute indiana. Asking 7500 obo
