'72 Duster starting And Running Problem
Electrical and Ignition
  1. '72 Duster Maddness
    '72 Duster Maddness Member
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    6:12 AM
    Hello Everyone I know You All Have Answered this Question a Hundred Times But This Is My First Mopar I've Recently Bought and when I bought It It Started Right Up image.jpg image.jpg
  2. Tooljunkie
    Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
    15,765
    15359
    Jul 22, 2017
    Manitoba
    Local Time:
    8:12 AM
    And then?
    The suspense is killing me....
  3. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    6:12 AM
    It Started to Sputter And Then Finally Stopped I've Replaced the Following: Distributor Cap And Rotor, Pickup Coil,(found this to be missing rivet at pivot point)Four Connection Rigistor,and Wires/Plugs Coil Is Okay Car Cranks Strong But Won't Continue To Run Wonder If I Missed A Step or Wired it back up Wrong ECU Has Four Pins
  4. Tooljunkie
    15,765
    15359
    Jul 22, 2017
    Manitoba
    Local Time:
    8:12 AM
    Four pin ecu is fine, need to check for power at ignition coil. Somewhere in this forum is a troubleshooting guide,with an ohmmeter and a test light you can find exactly what part is faulty. Price of the tools is cheaper than replacing parts willy-nilly.btw,ignition rarely causes a sputter, but a fuel problem does.
    Pull dist cap and see how much up/down movement it has.
  5. TrailBeast
    TrailBeast AKA Mopars4us on Youtube
    21,433
    9048
    Mar 11, 2011
    Arizona
    Local Time:
    6:12 AM
    Also check that stupid 2 pin connector where the distributor connects, as I have had two cars that had issues because of that plug.
    Squeeze the female socket on each end of that plug to make sure they connect.
    It does sound like a lack of fuel though.
    Does it shoot fuel into the carb when the throttle is pumped?
    Is there a spark to ground out of the distributor end of the coil wire?
    Or if you put a timing light on the coil wire and crank it does the light flash about every 1/2 second?
    Answer these and you'll find your problem.
  6. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    6:12 AM
    Thanks Tooljunkie I'll Look That Up When I Get Back I have The Tools Worked for A Company That Made Custom Indoor Spas and Bathtubs and did You Mean the Dist.cap Or the Dist.
  7. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    6:12 AM
  8. TrailBeast
    21,433
    9048
    Mar 11, 2011
    Arizona
    Local Time:
    6:12 AM
    The distributor center shaft under the rotor is what he means. (how much up and down play)
    Factory distributors are a two piece design, so this could be misleading as some of the play will be the top section moving.
  9. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    6:12 AM
    I Will Also Check These Out When I Get Back Thank You Again Gentlemen!!!
  10. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    6:12 AM
  11. '72 Duster Maddness
    19
    3
    Sep 4, 2017
    La Puente Ca.
    Local Time:
    6:12 AM
    I Have Found Out That The Coil Was The Problem Can Anyone Suggest A Good Replacement Coil I Heard A Coil Of UC-16 Is What I Need And Thank You Trail Beast I Did Change The Connection Coming From The Dist
