[FOR SALE] 72 duster street legal drag car.
Cheapstreetduster
been here a long time
Georgia
Rating - 0%
0   0   0
1972 plymouth duster drag car.
368" small block all steel. street legal racecar.
ENGINE early 360 block .040 . 0-balanced factory crank, lightened/polished stock type rods, KB107 hyper pistons. Balanced rotationg assy. 1790 bob weight.
solid flat tappit cam.
HEADS. extensively modified J-castings with t/a pushrod relocation. Ported runners. 2.02" valves with Crane offset roller rockers. flow aprox 266cfm at .500" lift
Eddies single plane intake with proform 780cfm carb. leanburn dist. with MSD 6al Ignition with adjustible timing retard, rev launch 2step.
Moroso electric waterpump .TTI step headers
FUEL 2 Holley black pumps cannister filtration. 1/2 fuel line. race fuel tank in trunk. Batt shut off ect...
NHRA Tech inspection safety equiptment.
TRANSMISSION Pro built 727 with transbrake. PTC 5200 8" converter. Aluminum driveshaft with 1350 joints . drive shaft loop.
REAR AXLE 8.75 with pro 4.30 gears, strange spool,Mark williams billet caps, and Moser large bolt axles. large factory drum brakes. Super Stock springs and spec;d shocks.
FRNT SUSPENSION, factory K Frame. with modified lca. Heim Joint strut rods. Drag T-bars, Stock large disc brakes. and drag shocks.
WHEELS forged Centerline telestars 4" fronts with Moroso skinnies. 8" rears with M/T 29"-10.5 slick.
CHASSIS subframe tied. 10pt Chromolly cage with window net and harnesses. race seats. stock dash, door panels and headliner. factory steering column and tuff wheel. full carpet. No backseat ..Batt in trunk with
ALL STEEL BODY .factory chrome bumpers and glass.
steel hood with factory A-body scoop.
8yr old paint with period painted graphics on roof and trunk. Volvo jade green
all lights and signals work. Sharkstooth grille.
Body is straight and clean. Shiney older paintjob
change the oil adjust the valves. fresh plugs,gas and a fresh bottle and go racing.
7.30 et on motor 6.67 on no2
POWER ADDER NOS single plate N02. .72 pill.
Need space in garage and kids and sports leave me no time to race.
testing the waters. $16000 will consider all serious offers.
Car is located in north Georgia.
Needs front and rear window trim/bright stainless trim..
has some small bubbles in rear wheel wells.
some minor chips,scratches and a ding or 2 (mostly from sitting in the garage)
paint on steel hood is faded and or checking.
NO Rust anywhere else.
Pm me here if interested.
a couple Videos [ame="https://www.youtube.com/watch?v=X6cIjrrB7bQ"]Cheapstreet at the Mopar Southern Nationals! - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=yp-H7KnHp94"]cheapstreet duster time run 6.76.AVI - YouTube[/ame]
Attachment​
Attached Thumbnails http://www.bigblockdart.com/forum/attachment.php?attachmentid=38970&d=1409882573 http://www.bigblockdart.com/forum/attachment.php?attachmentid=38978&d=1409882625 http://www.bigblockdart.com/forum/attachment.php?attachmentid=38986&d=1409882652 http://www.bigblockdart.com/forum/attachment.php?attachmentid=38994&d=1409882681
ok thanks.
