1. sorewrist1
    sorewrist1 FABO Gold Member FABO Gold Member
    289
    25
    Mar 18, 2012
    Sac Cal
    Local Time:
    8:49 AM
    I have a 727 behind a 360 in a swinger. The trans was just rebuilt by a tranny guy I trust. Its been sitting a couple months as I had to replace a heater core. I took it out yesterday and backed it out to the street put it in drive and when it got to 5 mph the back tires locked. The idle came down and it moved again to 5 mph and the back tires locked again. I went home put the rear on jack stands. I started it up put it in manual 1st no lock Put it in manual 2nd lock. Idle comes down and the wheels spin again. Drive same thing locked. A couple of things to add. when I first put the trans back in Reverse blew in a couple minuets. A little piece of metal 1X3/4X 1/8 that the reverse band pivots on broke in half. Replaced that and got reverse back but had to put it in drive first to get reverse to fully engage. Trans guy says pull it out and I'll take a look at it. any ideas before I do that thanks guys
  2. lkopaska
    lkopaska FABO Gold Member FABO Gold Member
    388
    401
    Sep 19, 2012
    DesMoines, Ia
    Local Time:
    8:49 AM
    Yep pull it out, rev band locked on , locking rear tires on 1-2 up shift.
    Lon
    • Agree Agree x 1
    • RustyRatRod
      RustyRatRod I was born on a Monday. Not last Monday. FABO Gold Member
      71,464
      46594
      Jun 7, 2010
      Georgia
      Local Time:
      9:49 AM
      Sounds like maybe he adjusted the reverse band too tight. Had it happen myself. The shop even pulled it went back through it and put it back in at no charge.....and it was originally a bench job. Good luck. Sounds like he's gonna fix it. I agree with him, I think it's gotta come back out.
    • sorewrist1
      289
      25
      Mar 18, 2012
      Sac Cal
      Local Time:
      8:49 AM
      thanks guys will pull it
