1. EvilScamp
    EvilScamp Well-Known Member
    3,309
    3
    May 22, 2004
    Dalton PA
    Local Time:
    12:11 AM
    I have been fighting trans. issues for a while now thought they were all straightened out. Got the Duster out for the first time this year a couple days ago, worked great for a while nice firm shifts but after 5 or 6 miles when i would stop it would pull out fine but when it went to shift it would start slipping i put it in neutral then back in gear again it would go until it went to shift and would slip bad.
    I'm not a trans guy by any stretch and talked to a few guys about it i been told it could the front pump, the accumulator, the valve body or even a crack in the case.
    The fluid is full, that was the first thing i checked, can anyone give me any better ideas before i pull it out again?
  2. Zippieisit
    Zippieisit Member
    7
    0
    Apr 13, 2015
    Titusville, FL
    Local Time:
    11:11 PM
    Have you ever changed the Filter?
  3. kiss
    kiss Well-Known Member
    850
    395
    Sep 1, 2008
    San Diego, CA
    Local Time:
    9:11 PM
    Also are the cooling lines clogged?
    Also check for a clog at the radiator cooler fittings, or external cooler if you have one
  4. bOb shingler
    bOb shingler Well-Known Member
    3,250
    163
    Jun 8, 2007
    warrenton, north carolina
    Local Time:
    12:11 AM
    rebuild it.
  5. Corrupt_Reverend
    Corrupt_Reverend Well-Known Member
    279
    171
    Jul 15, 2012
    California
    Local Time:
    9:11 PM
    +1
    It's easy!
  6. EvilScamp
    3,309
    3
    May 22, 2004
    Dalton PA
    Local Time:
    12:11 AM
    Already did rebuild it everything in it is new also installed a trans go shift kit.
  7. MobileCustoms
    MobileCustoms Well-Known Member
    1,708
    1679
    Oct 21, 2013
    Inver Grove Heights, MN
    Local Time:
    11:11 PM
    Did you check the fluid level while it was in neutral, not park???
  8. thesiren74
    thesiren74 Well-Known Member
    1,620
    1217
    Feb 23, 2014
    kenosha,wi
    Local Time:
    11:11 PM
    Drop the pan and check the band's .
  9. OldmanRick
    OldmanRick Well-Known Member
    7,030
    316
    May 11, 2012
    Ladson, Sc
    Local Time:
    12:11 AM
    Kick down/throttle pressure linkage???
  10. AJ/FormS
    AJ/FormS 68 B'cuda fb, Form S clone ... 367/A833/3.55s
    20,798
    8169
    Jan 19, 2014
    South-Central Manitoba,Canada, 900ftelevation
    Local Time:
    11:11 PM
    And finally, what oil ?
