73 318 main bearing caps
adweeks
Member
Rating - 0%
0   0   0
I am looking for a set of 318 main bearing caps. Please pm me if you have any or a lead on a set. I am located in Crystal River FL. Thanks, Anita
You do realize that you cannot just bolt on a set of caps to the block, right? If you put on different caps then were on the motor originally, the block/caps need to be lined bored.
Not a good idea,should be able to find a complete 318 fairly easy.I would give you one but the shipping from st louis would be expensive
318 not a high dollar engine,lots of cores cheap,or runners cheap
I should have a set if you can't find something closer. Sometimes you can get lucky and only have to align hone instead of bore but no guarantees.
Thanks, Mark
I have several sets so if the ones from cudamark don't work out, let me know. Comes with the bolts.
Ken
Edison, NJ
