73roadrunner340
Member
Mopar 340 Short Block. Motor is a 73 Casting. Motor has steel crank and is drilled for a 4spd. The rods and harmonic balancer are with it. It is freshly bored 60 thousandths. It is a tight bore so that new pistions can be fit by honeing. Motor The block has been sonic tested for cracks. $600 Thanks Motor is located in Burlington Wyoming.
