73-76 D/side Lower Control Arm w/sway bar tab
Dusteriffic
Stink finger
San Diego, CA
NEED: Driver's Side 73-76 Lower Control Arm with Sway Bar Tab
Before retro-fitting a sway bar onto my Duster, I discovered the LCA & bar assembly I bought years ago has a tweaked driver's side LCA.
Anybody got a single they want to give up?
PM me here with your total to 92024 - Steve in SoCal
You can buy a pair of tab from Hotchkis for $29.95. Then have somene weld them on your non tabbed LCA.
These are the same for A-bodies. Copy the placement measurements off of your bent LCA you have. http://www.hotchkis.net/late_mopar_control_arm_bracket.html
They sure look similar, but Hotchkis doesn't state an application for A-body. I wonder why.
I priced it out and it looks like it might be a less expensive way to go than picking up a used LCA.
Do you have these on your A-body?
Hey I am located in Oceanside. I am not sure what part or Cali you are in but I have a pair of them I would be willing to sell. Something like 45 bucks for the pair. I would rather not seperate them because then I would have one for no reason. Also you could keep the other in case it gets tweaked somewhere along the line.
Jeff
775-772-4926
I have stock E-body and stock 73-76 A-body sway bar LCA's around. I've put them next to each other and examined them. They will interchange.
2 E-body LCA's with bend one on left. 1 73-76 A-body LCA with measurements for fabbed sway bar tab (before hotchkis came out with them)
Wow, that one on the left looks as bad as mine.
Anyway, I just acquired a set from "JeffTheMarine". After a little clean up, I'll be good to go.
Jeff, good luck with the Demon. I'll keep you posted about the carb.
