[SOLD] 73-76 front disc brake setup
moparmat2000
Grand Tetons
73-76 disc brake setup. What you see is what you get. M body spindles, A body discs, calipers, and UCAs. One UCA has new bushings, the LH one needs bushings pressed in. New bushings for that arm are included. AFT bushing hole on LH arm appears to have a tack weld repair for a loose bushing. Could easily use polyurethane insert bushings in the arms and just leave outer sleeves alone instead. Does not come with bolts to mount the spindles, but those can be had easily at your nut and local bolt place. See screen shot below for type of bolts and nuts to get for the lower ball joints. Nuts used are mechanical locking "stove" nuts NOT nylock nuts. 2&1/2" is closer to the right length. Rotors are pretty thick, will clean up good on a brake lathe. If you dont want the rotors I can take em off to save weight $350 with rotors, $300 without rotors. Via UPS ground. Located west Texas. I accept pay pal.
