[SOLD] 73-76 LBJ Upper Control Arms/Disc Spindels
65 Dartman
1 of None 65 Dart Sedan Delivery
Strasburg, VA
I just pulled from the 65 Dart I'm parting out the 73-76 large ball joint upper control arms and 73-76 disc brake spindles with caliper adapters. I previously used the upper control arms on a 70 Dart I used to have and swapped them into my 65 Dart along with a set of crusty looking 73-76 disc brake spindles to keep the car mobile. I only have 1 dust shield and will include it. Since I'm parting the 65 out, I won't be needing these for my Dart wagon as I have another set ready to install. I can provide core rotors and calipers if you want them. I would prefer to sell the UCAs and spindles as a package. If desired I will separate the UCAs and spindles. $225 for the UCAs and spindles plus shipping (probably in a couple of flat rate boxes). If I separate, $125 for the UCAs and $125 for the spindles plus shipping. Any question, don't hesitate to ask.
Spindles are sold; still have the large ball joint upper control arms.
I had a question about the ball joints and bushings on the UCAs. I had previously rebuilt both UCAs and installed them on a 70 Dart I had. They might have had 1500 miles on them prior to parting the car out. Both ball joints are tight and still filled with grease, the boots are not torn and although there is some surface rust on the exposed part of the bushings, they are in my opinion, virtually new. I would say the UCAs can be installed as is. My plan for the Dart I'm now parting out was to use these UCAs just as seen (well, maybe give them a wash and re-spray the black. They're already packed in a large flat rate box and ready to mail out.
